Results 1 to 6 of 6
Thread: Recommended VW Suspension Specialist in SA?
    Whyalla SA
    Hi all, been slowly accumulating upgraded suspension components for my mk6 gti; will be planning on installing soon; can anyone recommend a quality specialist in SA? Cheers
    Dec 2015
    Crafers, South Australia
    Talk to the lads at German Auto in Edwardstown. Fantastic to deal with, good pricing, know VW back to front.
    MY16 Golf R
    Whyalla SA
    Cheers mate, I know them well, more than likely will use them
    Whyalla SA
    So, got motivated last night and decided to fit my 22mm Super pro rear sway! Bit of mucking around as I had to remove the Unibrace Rear Brace, which also meant dropping the back section of the exhaust; apart from that, everything went well and since this is the first suspension mod to go on, (apart from all 3 Unibraces), I followed the included instructions and set the bar to full soft to begin with. The result is amazing! The handling is already greatly improved and has left me wondering how much more improvement is to come when the Super pro 24mm front sway, VWR springs, Bilsteins b8, Supaloy LCA's, front & rear Tyrolsport deadset collar kit, 034 motorsports strut mounts & rear trailing arm bushes go on! I'm super impressed with the quality of Super Pro gear, so I've decided to wait for their adjustable endlinks when they become available later on in the year.
    Just need to get the dcc cancellers, either KW or the iSweep Ishikawa ones and the Vibratechnics dog bone bush, to match up with my VWR subframe pucks, then all will get installed so as only need to drop the front subframe once, phew! As you can imagine, wallet and credit card are on life support and wifey's patience wore thin quite a while agoRecommended VW Suspension Specialist in SA?
    Apr 2013
    Quote Originally Posted by GoddyB View Post
    Can recommend Whiteline adjustable endlinks if you can't wait, readily available and cheap and I swear made a big difference to the handling of my already KW lowered Polo GTI.
    Also would recommend Buik Motorworks Keswick for any specialised work, they are mainly Porsche but some really good mechanics there.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
    Whyalla SA
    Quote Originally Posted by car_nut View Post
    Thanks for the tips, good to hear the Whiteline's have made a noticeable improvement, and as you say, the price is right, because this is getting very costly and still have to get some bolts & ball joints etc.
