Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Rear Swaybar Problem
    Its a 25mm sway bar and after a few days of drivng around it is bloody awsome. Reduced soo much body roll and tightened up the rear end heaps. Best sus mod so far
    Lucky we live in the driest state etc. Stiff roll bars make a car real twitchy in the damp. My MK1 GTI was slower in the wet because of it. No weight transfer onto the outside wheels so no increase in grip.
    Awesome in the dry though.
    Sep 2008
    bne.qld.au
    Is the OEM bar 17 or 18mm?
    Just trying to work out if upgrading to 22mm will be enough, as 17>22mm is already 180% stiffer than stock.
    25mm is almost 400%!
    Sep 2006
    West Sydney
    Stock Mk3s don't have any rear sway bar at all, just the front.
    I don't know if you can count the beam as a sway bar...
    Sep 2008
    bne.qld.au
    Oops...
    Perhaps I should have specified I was talking about a MkIV Golf/Bora.
    Nonetheless, it's all about body control and weight transfer. So I can only assume that going from no bar to 25mm would be an even more marked difference than upgrading from a smaller OEM bar.
    Oct 2005
    Dandenong North, Vic
    Quote Originally Posted by rayray086 View Post
    Isnt there one running inside the beam like on a MK2 GTi ?
    MK2 GTI G60
    Oct 2006
    Nup there isnt, but u can buy one that runs on the inside and drill holes thru that rear beam to hold it up, its supposed to do wonders as well
