Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rear Camber
    Aug 2006
    Rear Camber
    do our VW's camber in at the rear the more you lower it?
    wen you lower a bmw or commodore, the rears camber in so it doesnt hit the rim. does our VAG cars do the same??
    Dec 2006
    Kilsyth, VIC
    Only if you have IRS. The old Type III did, as do most aircooled vehicles. AFAIK the Golf range does not. Passats... well I'm not sure.
    Aug 2006
    Quote Originally Posted by The_Hawk View Post
    kool thanks.. how do you know if it has IRS or not.. is there something i should look for?
    I'm pretty sure the audi A4's do - so i presume the passats do but don't quote me on that.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Sep 2006
    West Sydney
    I know cars using a rear axle beam don't cause more negative camber as you lower the car, but it will make the wheels sit further towards the front due to the action of the beam (is that positive or negative castor?). However, if you want to generate camber, you can use camber shims. They bolt up between the stub axle and axle beam.
    It's unnoticeable in the picture but in extreme cases, you can physically see that the bottom of the shim is thicker than the top, thus allowing your tyres to sit on an angle. Purely for racing or show-only purposes as you can imagine.
    Aug 2006
    Melbourne VIC
    Oh yeah camber shims... I think i may have ordered some of those
    Jan 2008
    One of my mates has a 97' Audi A4 which has been lowered around 2' or so and I have not noticed any neg camber on his car.
    gpk_gti Guest
    I dont understand you ray,you keep trying to do things to a passat that will either make it look like a beemer or a skyline. my suggestion is sell the car and buy somehing you really want.much cheaper in the long run.
    Nov 2006
    Quote Originally Posted by 1DUB2C View Post
    lol you make it sound like a feature but it's really a BAD thing - Will wear through your tyres like you wouldn't believe and cause the car to handle like ****.
    Gosford Central Coast NSW
    IT ALL DEPENDS....
    cars like commodores with IRS end up with lots of neg on the rear when they are low because of the angle that the rear wishbones rotate through to get to that position.... its not by design that the tops of the wheels end up with more clearance. generally anyone who does this on a commodore then eventually gets a camber kit put in so that they have less neg.
    im infamiliar with the passat rear suspension (on the new passats atleast) but i trailing arm golf suspension allows little change in alignment with ride height, which is nice.
    i would suspect that like bmw's and audis with IRS, there is much less transition to neg camber on th rear than the notorious commodore.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
