Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Questions about changing wheels.
  1. #21
    Jul 2011
    Melbourne, Vic
    So to keep it legal, I could go 18s with 235/40/18 tyres as a max, but 225/45/18 would be illegal?
    MY11 VW Golf 118tsi, Silver, 6 Speed Manual, MDI, RCD510 touch screen, tinted windows.......more to come.
  2. #22
    Quote Originally Posted by fully View Post
    The usual 18 on a Golf is 225/40 - so if you were looking at keeping an OEM look and picking up GTI/R 18s then this would be on them.
  3. #23
    Jan 2009
    Yes, that's fine.
  4. #24
    Jul 2011
    Melbourne, Vic
    Quote Originally Posted by Diesel_vert View Post
    Yes, that's fine.
    Will there be any issue on vw stock 18s with rubbing?
  5. #25
    Not on 18 x 7.5 (Detroits) or Talladegas (18 x 8?) using 225/40 rubber. It may look a little '4wd-ish' on 18s, you may wish to consider a mild drop in ride height to complete the look.
  6. #26
    Jan 2009
    Can't say for certain. It will depend on the wheel offset and suspension setup. Sticking with the OEM wheel and suspension will minimise any chances of rubbing. More aggressive setups will increase it.
    That reminds me:
    Fitting a 235/40 R18 tyre on a 8.0J x 18 wheel is acceptable, but will render the vehicle unroadworthy if fitted on a 7.5J x 18 wheel.
  7. #27
    I just had 18" x 8.5 wheels put on my Mk5 Golf with 235/40r18 tyres. Absolutely no rubbing and in terms of ride, I've only noticed a very slight difference, ie a bit firmer ride and feel bumps slightly more (old wheels were 17"x 7 with 225/45r17 tyres). I'm hoping the trade off is more traction with 10mm extra width rubber on each corner.
