As the title states, i can hear clonking noise when turning my steering wheel at low speed or stationary, more so when turning left.
During the coilover install, one of the mount bearings fell apart when it was taken off the OEM strut, some of the mini tiny balls came off and had to be put back carefully, then the bearing rubber put back on.
Is there another fix solution beside replacing the top strut mount with SKF mount bearing and/or put Whiteline insulator / sleeve on the springs?
I'd like to hear from anyone who has actually experienced a similar problem and found the solution.
