What are your tyre specs btw?
I would run a bit higher than that maybe 37psi as you always want the tyres to be filled to minimise the chance that the stretched tyres will pop off the bead of the rim under load.
Dont forget to regularly check tyre pressure but as long as its not crazy stretch i wouldnt worry too much.
