Results 1 to 6 of 6
Thread: Poly Bushings in MKIV R32
    Mar 2012
    Brisbane, Queensland
    I have so many darn squeaks and creaks travelling on any road surface. I have heard this could be due to the polyurethane bushings I have???
    If so, how much is a full replacement set of OEM rubber bushings going to cost and where can I obtain them?
    Cheers,
    Jed
    No. 164 - HPA Competition Haldex Controller, KW V3's, Southbend Stage 2 Singlemass Flywheel, Simota Racing Air Intake
    Quote Originally Posted by JedR32 View Post
    Cheers,
    Jed
    Give everything a squirt with some lube Jed. It's a fact of life with poly, getting it 100% free of noise is tough. The rear front wishbone bush in particular is prone as it is getting twisted rather than rotating.
    I'd probably get them replaced with the std ones and see how that goes, if you are determined to removed all the poly.
    I don't have any poly on my S3 and that still makes horrible noises.
    Mar 2012
    Thanks Gav
    I think I'll try and replace it with all the standard bushings. How do we get rid of all these damn creaks and squeaks!?
    I wish there was a single remedy for all of them haha
    Jed
    Apr 2006
    VW Race HQ - Sydney
    I find that most people dont change the sway bar bushes which dont come in the refresh kits . Re-tightening the bolts is a must after 1000 or so kms . Really shouldnt need to lubricate the bushes as dirt/dust gets stuck to it a lot easier .
    Bug_racer supports the rebellion of the euro revolution
    Mar 2012
    Quote Originally Posted by Bug_racer View Post
    Do the swaybar bushings tend to make clunking noises? And do you have any fixes on interior rattles/squeaks?
    Cheers,
    Jed
    Dec 2012
    Sutherland Shire, Sydney
    I only have harder rollbars with special bushings and they squeak
