Results 1 to 10 of 10
Thread: Audi Wheel to passat
    May 2009
    Canberra
    Hi all. I'm just about to pick up an 18 inch Audi A8 Quattro 2008 model rims. And I just need to get some clarification if this rims wil fit straight in to my 07 passat. Are they the same PCD and off set.
    Audi Wheel to passat-image-jpg
    2009 Tiguan TDI and 2007 Passat TDI
    Quote Originally Posted by revhead1016 View Post
    Whats the details on these wheels? They numbers will be on both wheel sets, on the back.
    May 2009
    Canberra
    Just contacted the seller for the info. Will let you know soon
    Wheels are 18x8et43 most likely?
    Your passat is 17x7.5et45 or something.
    Which is basically the same
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Erskineville, NSW
    They should fit - about the only ones that are a bit weird are the A5 because the offset is ~ET27
    May 2009
    Canberra
    I did some research and the passat is
    PCD Center bore Offset
    5x112 57.1 45
    The Audi is
    5x112 57.1 42
    Offset is a bit different. Wonder if this will cause any issue
    Erskineville, NSW
    The offset changes dynamically with the width. Suggest you bung your diameter, width & offsets into a wheel calculator & you'll see what I mean
    1010TIRES.COM - Wheel Offset Calculator
    Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
    May 2009
    Canberra
    Thanks brad
    Look on the back of the new wheels, write down the specs.
    Look on the back of your stock wheels, write down specs
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2009
    Canberra
    My passat is 5x112 ET47
    The Audi is 5x112 ET47
    Perfect fit
