PLeaseeeee pleaseeee pleaseeeeeee...use the search tool!!!!!!
1. what typre of car do you have?
2. you will most likely only be able to use adapters...Adaptec Speedware
Hey Guys,
Not sure if this has been covered before, but can I convert the stud pattern to 114.3 PCD? I wanna go for old skool Jap rim, but finding what I want in the right size, offset AND pcd is proving difficult!
Cheers!
Robbie G.
ok so you have a vento...
find out what wheels you want (specssss) and find the perfect offsets you need and then run 4x100 to 4x114.3 min thickness being 15mm
as above hit up adaptec. with the cheap prices of jap wheels makes sense to spend a few $$ on adapters. you'll be looking at ~$400 posted. for simple 4 to 4 stud
Absolutely, found plenty off low offset 15s going for ~4-600!
Thanks for the deets guys![]()
Cheers!
Robbie G.
