Results 1 to 7 of 7
Thread: offsets
    Aug 2006
    offsets
    how do offsets work.
    10" wide rim with et 43
    sorry!! start again
    stock passat is 7.5" et 35
    Sep 2006
    West Sydney
    That sounds ****ing nuts. The offset is too high on a 10". Your tyre or even your rim may hit the suspension because it sticks so much more into the middle of the car.
    Edit:
    The wheels are sitting in at about 5cm more than standard, which is a massive difference when it comes to wheel fitment. The 10" wide wheel will stick out only a little bit (12mm). Only way it'll work is with spacers, and a whole lot of fender rolling!
    Aug 2006
    so i need spacers?? any idea how thick?
    Jun 2007
    Eastern Suburbs Melbourne
    50mm spacers?? hmm. doesn't sound right does it, but that's prefft much the diff between the backspacers. but I'm not sure.
    Ray, what program did you get those pics from? that Look's like a very handy program!!
    i like volkswagens
    Aug 2006
    ray can u calculate it again plz.. updated the details on 1st post.. had the wrong et n size.
    Sep 2006
    West Sydney
    I use this a lot: http://www.rims-n-tires.com/rt_specs.jsp
    There's a bug with it though - it doesn't update the summary table thingy towards the bottom of the page when you change offsets and widths, so make sure you refresh the page every time you put in a new pair of widths and offsets.
    Ray, with ET43 on the same width, you're looking at the same setup, except it'll clear the suspension by 5mm and poke out 5mm more compared to ET48. Think of it this way - ET43 is ET48 with 5mm spacers.
    Jarred, 50mm spacers would make sense as you'll clear the suspension and any other bits under the fenders BUT Ray's Passat would look like rollerskates!
    In respect to the correctly sized spacers, I don't have the answer to that... I don't know how well 10" wheels would fit under the arches of the B5 Passat. But a 10" replacing a standard 6.5", you'll have troubles no matter what!
    Ray, what are the size and offset of your current wheels? We could compare that to the 10" wheel, and whatever difference there is, you could measure out to see how it might look.
    Jun 2007
    lol, roller skates. I find wheels too confusing most of the time! thanks for that link though.
    i like volkswagens
