Results 1 to 10 of 12
Thread: Noisy clunking endlinks after fitting KW coilovers?
    Apr 2013
    I was initially happy after install of KW Street Comfort Coilovers to my 2015 Polo GTI BUT started to get clunking from the front suspension and it eventually became unbearable. Took car back to Pedders who did the job and they had no clue.
    At the suggestion of BWA (who sold me the KWs) I took the car to Buik Auto (Adelaide Porche specialist/APR agent) and young mechanic quickly identified that it was the endlinks (std VW. The link rods, about 300mm long fit between the coilover mount hole and the ARB), movement in ball type joints (car done only 3,000ks). Took them off, no clunking, refitted them and there has been no clunking since???????????
    Anyone else had noisy endlinks after fitting coilovers. Can these endlinks be fitted wrong way around? Why has the noise stopped? Will it start again?
    Tried Harding and BWA and there are no aftermarket endlinks for my car if this noise does come back.
    Also posted in Polo forum. Looking for answers.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
    Just be happy that the noise is gone Noisy clunking endlinks after fitting KW coilovers?
    Oct 2010
    Melbourne, VIC
    Could Pedders have not torqued up one end of the endlink enough so it worked a bit loose over time?
    Resident grumpy old fart
    Apr 2013
    Quote Originally Posted by kaanage View Post
    Thanks but doubt it after they specifically told me they checked the end link bolts when I took it back to Pedders.
    Yes I'm happy right now tigger73 but just being pessimistic about the outcome.
    Well look on the bright side - at least you know where to get it fixed next time.
    May 2015
    aus
    Was it clunking on every bump or only noticeable at slow speeds on like full lock?
    Apr 2013
    Angry
    Quote Originally Posted by NuffNuff View Post
    Almost continuous clunking at all speeds over any minor-major road imperfections. Most noticeable at low speeds, it's a noise that was transmitted up through the body from the front sway bar/endlink joints, drove me nuts! Pedders were useless at diagnosing it and went back on their word that they would do any required height adjustments etc after a month. Ride height had dropped about 6 to 8mm in 4 weeks and car was lower than KW's recommendations, ended up fixing that and making some rebound adjustments myself. After sales service - you pay and then they do not want to know you!
    With your just fitted Eibach springs I expect you may notice some minor spring clanking, particularly when eg turning into your driveway?? Had this with my previous Eibach Pro kit/Polo GTI, nothing drastic and something I could live with.
    May 2015
    aus
    no weird noises at all with the Eibachs, my BC coilovers in my legnum bind at pop/crack sometimes on full lock in the driveway
    i'd only go to pedders if all you want to do is a wheel alignment on a regular car or slam a falcodore, i had my own experiences with them 10 years ago. i prefer smaller businesses and not chains
    Jul 2007
    Brissy
    Sometimes just flipping the end links over quietens things down.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Apr 2013
    The knocking came back!! so I fitted Whiteline adjustables and noise has gone again, hopefully for good this time.
    Found that a couple of the VW knuckles/ball joints were locked up and took a bit of force to get them moving again.
    Attached Thumbnails Attached Thumbnails Noisy clunking endlinks after fitting KW coilovers?-whiteline-droplinks-jpg
