Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: new to wheel offsets
    Sep 2006
    West Sydney
    Quote Originally Posted by straight_fresh View Post
    you could get 4mm machined off the +40... im pretty sure iv said that right, but more importantly, what wheels are they!!!???!?
    Quote Originally Posted by dubbed_up_daz View Post
    that ^ would make it et36,if all four wheels are the same width youll need to run a 4mm spacer on the 40 and youd be better running it on the rear. Offset is the distance 'from' the hub face to the centreline of the wheel so if you machine the hub face you are decreasing the et
    That's NOT right. 4mm machined off the mounting surface of a wheel at ET40 will INCREASE the offset to ET44. A +40 offset means the mounting surface sits 40mm away from the centre of the wheel, towards the outer rim. Machining 4mm of material off the mounting surface will increase the distance of the mounting surface of the wheel to the centre by 4mm, hence changing it to a +44. Or just think of it this way - if adding spacers ("adding material") lowers offset, then machining off material should mean an increase in offset.
    dylan8 also has a point about offset being dependent on the width, but we're assuming here that all the wheels (ET40 and ET44 variants) are of the same width?
    Edit: dylan8 beat me to it! The paint fumes are doing you good mate.
    Dec 2008
    Perth
    hey daz wouldn't adding the spacer on the 40 effectively push the wheel outward more increasing the amount it pokes and decreasing its offset?
    wheels are a set i've had sitting about for a while, decided to polish them up and get them on until I get time to clean up the bbs
    i'm strangely addicted to them
    Dec 2008
    Perth
    and you two both beat me to the line haha
    Sep 2006
    West Sydney
    Awesome wheels, space them out for sure!
    Mar 2010
    perth, W.A
    yes, putting a spacer on the +40 will make it +36... i thinnk your best bet would be machining the +40 down 4mm, i thought those wheels had potential, colour matched slots would make them look awesome!
    Dec 2008
    Perth
    yeah I would like them to be all the same, but I don't think there's going to be enough meat on the back to take 4mm off the +40 as there's a bit of a countersink for the wheelbolts. plus if i put the spacer on the +44 the rears will be a touch wider which would work out well
    Jan 2008
    Canning Vale, Perth, WA
    Persoal taste and everything, but in my opinion those wheels might look a lot better with tyres on them! LOL
    Quote Originally Posted by dubdan View Post
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Dec 2008
    Perth
    Quote Originally Posted by gareth_oau View Post
    ha ha they're superduper low profile ones at the moment gareth,,, Persoal favorites of mine
    I dont know how I got that so arse for tit :s I blame long hours and a high alcohol intake
