Results 1 to 10 of 12
Thread: new springs, or cut the old ones?
    Mar 2013
    bulimba qld
    Lightbulb new springs, or cut the old ones?
    Hey guys i want to bring my mk5 to a more stanced height, but i would prefer not to mess around with changing to coil overs, and just keeping it as close to stock suspension wise. So the question is should i get new coils or cut the originals? And can anyone recommend a garage that can do this job locally (Brisi)
    Jun 2009
    Don't dare cut the original ones, that is a terrible idea.
    You can get a set of lowered springs and use the same struts for about $300 landed
    Nov 2012
    Melbourne, VIC
    Re: new springs, or cut the old ones?
    Please don't cut your springs
    Mar 2013
    bulimba qld
    mad, haha sorry didnt really know not to cut X) thanks, wiser now
    anywhere i can pick some up from??
    Jun 2009
    Quote Originally Posted by skyliner3495 View Post
    Volkswagen - Golf V 1K - Fahrwerk - Sportfedern - Sportfedern VW Golf 5 - Orange Tuning
    http://www.awesomegti.com/car/vw/golfmk5?subpart=456
    As the others said, no cutting. Its not a falcoon.
    You won't get low enough on chopped springs or aftermarket springs to give you 'stance'
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2012
    Sydney NSW
    OP and anyone else that doesn't know....
    Springs are slightly tapered and coiled flat either end to hold captive the spring rate and hold the spring in place - it's the stupidest thing to cut this spring anywhere along its length.
    That would cause unpredictable shock movement and the spring itself would no longer be captive , promoting the possibility of it catching mid stroke and causing issue or accident.
    It's also impossible to properly judge the end result even by measuring coils cut etc
    If you must lower it get some high quality springs like eibach etc. even kmac or king springs are a better alternative to simply cutting !
    Mar 2013
    bulimba qld
    ok guys i got the message from the begining, no need to keep telling me not to cut them....i understand.
    On a lighter note..thanks for the heads up, thanks Team_v for the links i appreciate it, now just gotta find the Funds
    Sep 2006
    West Sydney
    Hey, don't cut them.
    Mar 2013
    bulimba qld
    thanks mate, didnt gather.
