Results 1 to 10 of 10
Thread: New rims but scrape on calipers....
    Mar 2013
    bulimba qld
    Lightbulb New rims but scrape on calipers....
    just bought some custom rims from a great bloke, unfortuantly the rims will scrape on the calipers and i was wondering if there was any other way of clearing them, (only the front), without using spacers obviously, at the moment they have very little clearance like 2mm, but if i need to change the pads they will definetly scrape.... :'( any solutions????
    On his GTi he had no clearance, mines a mk5 FSI pretty stock
    P.s. new dubber
    What sort of wheels are we talking about?
    Have seen guys taking a mm or two of material off the caliper, but its not something you just want to muck around with
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Pacific Paradise QLD
    Obviously the wrong offset or the wrong rim diameter . You do realise spacers are illegal on the road.
    Perhaps not a good buy.
    OP, you say they scrape in one sentence and then there's 2mm clearance mentioned in another? Will the wheel rotate when bolted up or not?
    Mar 2013
    bulimba qld
    it does currently clear with the current pads, but probably not with new ones.
    also the guy says i can take them back if i wish, whats reccomended??
    btw im not gonna use spacers no matter what
    Quote Originally Posted by skyliner3495 View Post
    Take them back and buy some with proper offset etc They are obviously not the correct ones for that car.
    Grinding calipers may come back to bite you if anything breaks
    Mar 2013
    bulimba qld
    ok will do thanks for the awesome feedback, ill arrange for that to happen, thanks guys
    rookie error haha
    Offset isnt the factor that decides if a wheel will clear or not, its the design of the wheel
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2010
    Melbourne, VIC
    But wrong offset for that design
    Why not get a new set of pads (you'll need them sometime) and confirm the clearance (or lack, thereof) before returning the rims?
    Resident grumpy old fart
    Quote Originally Posted by kaanage View Post
    Yep exactly
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
