That's the one!
That's the one!
Eastern Wheel Works
Wheel Mods
Race Engineering
They all claim to be able to do the job. You might want to google people that have used them.
My old BBS had enough to take 8mm off the back.
A quick & dirty way of seeing what might be possible is to take the OEM wheel bolts & put one into a loose OEM alloy. Measure how much thread is visible at the back. Repeat with the aftermarket wheel. A-B= maximum machining amount. This would be before seeking a professional opinion.
Run them as is, streched tyres if need be, you wont get any grief from police
Yeah I'm after a legal fitment and not look so chamberish while daily driving!
Yeah just spoke to the wheel guy and no dice! So there gonna be up for sale-swaps
Just a question as Im unsure of the rules here. Is it legal to modify in any way a Mag wheel.
The reason I ask is because in NZ when running mags I had someone buckle one of mine just lightly on outer edge.
It was able to be cold rolled and was OK but was told that in no way could it be ground, drilled or welded.
Seems from this thread that it is common to do it here.
