Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: need wheel experts help!
    May 2011
    Albury, NSW
    If it's only that little I reckon you could:
    a) get the backs shaved down at the same time as the drill and fill
    b) pull your guards to cover that 2-3mm
    c) run stretched tyres so you don't rub against the guards.
    d) hope you don't get pulled by VIC Police.
    e) all of the above.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    May 2011
    Albury, NSW
    p.s. they do look absolutely amaze balls and will definitely be worth the effort you're putting in to them! I would've held on to them if I could've widened them out but imagine sticking another 25mm of poke on top of what you've got now - that's what I'd be dealing with haha!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Feb 2013
    doreen,vic
    Yeah f-that lol yeah I really love them so got to figure something out
    Erskineville, NSW
    Quote Originally Posted by defie View Post
    anyway to make it fit inside the bodywork?
    A wheel specialist should be able to machine the inner face of the wheel hub if there is sufficient metal to work with. It will depend how deep they have drilled the clearance holes for the wheel bolts.
    I know a couple of places in Sydney that can do it. Vic should have a few too. Even a machine shop could do it but they might not know how much metal you need to stop the bolts from pulling through.
    Angles on the photos don't really tell how bad it is
    Feb 2013
    doreen,vic
    I'm going to a wheel specialist Saturday, so hopefully I can get it all worked out
    May 2011
    Albury, NSW
    I'm running about 10-15mm poke at the moment - not daily though. I haven't done any arch work (unless you include burning the paint!) if I was higher I'd have no issues what so ever - seriously I wouldn't worry about it at all
    God that looks good from side on.
    You could shave the backs down, but being Bbs it would have been built to minimum as is most likely.
    Could just get them redrilled, mounted up with bolts and a second tyre or two and reevaluate
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Where you going. Cos the place closest to you from my knowledge is useless at the best of times
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Feb 2013
    doreen,vic
    Bloke up in lilydale can't remember the business name off the top of my head
    Feb 2013
    doreen,vic
    Quote Originally Posted by nightphotographer View Post
    God that's awesome but I'm after daily use!
