Results 1 to 8 of 8
Thread: Need help with wheel details for my mk5 jetta
    Oct 2012
    hey i own a 2011 mk5 jetta and i wanted to put on some 17 inch fat bbs rims on it but have no idea what my wheel offset and stud pattern is ? ( i was told it was 5 x 112 i think ) or any suggestions on what rims would suit my car ?
    Jun 2009
    Mk5 Jetta will be 5x112 and the Offset will be stamped on the inside of your wheel e.g. ET51
    A combination of offset, wheel width, bolt pattern and centrebore are required to get a correct fitting wheel.
    Oct 2012
    oh would this be on the stock rims ? cause i wanted to put bigger rim + tires
    Jun 2009
    Yes it would be on the stock wheels.
    That way you can use a wheel size calculator to work out what size you can upgrade to while still keeping it legal.
    Quote Originally Posted by team_v View Post
    This^^
    5x112 and 57.1 for the centre bore wont be stamped on the wheels.
    but the width and the offset of your current set up will be. as said above, use that to work out what you want
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Pacific Paradise QLD
    Use this best size comparator I know of
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Use internet explorer page doesnt like Firefox
    Oct 2012
    sweet thanks alot for the help !
    Oct 2012
    Oh i was thinking of putting some sport springs , any suggestions on what brand to get , or to even put them on ?
