need help with coilovers.
hey guys i recently ordered a set of pss9 coilovers.. i was wondering if i need any other parts to help with camber atfer lowering or its just install.. lower.. n get a wheel balance/alignment then im done.. cheers
Adjustable rear control arms. 1 set if lowering less than 35mm and 2 sets if lowering more than 35mm. Also I'd recommend reading some of the how to threads thoroughly if attempting it yourself as you'll need a couple of special tools.
Good luck with it and enjoy the heaps better ride.
Cheers Jared
Audi S3-White Lightning
hey jared if i lower more then 35mm i need upper an lower control arms right? do u have any websites recomeneded to buy these from?
cheers ben.
What are these for? mk4 r32 im guessing?
It wont help with camber but if the car has a few km get a refresher kit for the front end, or atleast some new bearings and TT mounts
- You may not post replies
- You may not edit your posts
Forum Rules
