it would be achieved by extending the thread that gets wound down when lowering the vehicle,then increasing pressure on the spring. Or either cuting half to a coil out of the spring try jdm forum mate.
i dont know much about this although i have heard about it
id like to go lower by modifying the coilovers, does anyone know what is involved?
cheers
dom
whoar! dont know about cutting a coil out! and also the tread on the coilovers stick out more than the shaft itself so i cant exactly make a extended thread because there isnt any metal to cut into
could there be an option to get custom springs made up?
dom
can you remove the helper spring at all??
i dont wanna remove or cut anything, i would like a complete shocker/spring setup, just modified for more height adjustment
dom
New spring quickest and cheapest way to do, and if you want to lower sell them just put the old springs in there.
? dude that means buying different coilovers...
just remove the small spring at the bottom... that way you get another inch of adjustment
its not doing anything now in your car because when the car is on the ground its fully compressed...so its just taking up ride height.
Stu
*cough* airstruts! *cough*
