The question is what [g] limit has the ESP been programmed for
Public road safety level or the actual car dymanic level
If the ESP is holding you back, you should be quicker with it off
Pushing wide just means you have to modify your driving because you've exceeded what the car is able to do
I can reccomend the supaloy lower control arms - the bushes are much firmer and it has more caster (anti lift)
My VRS Octavia had axle tramp and the supaloy control arms solved that
The initial turn in is now more crisp
I have the PS3 tires also - good all round road tire but has not met my expectations given the rave reviews
Did you put more pressure in the tires? ~42 PSI
