Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: MK6 TSI running MK6 GTI Suspension
    Dec 2013
    Hi All,
    Wondering if anyone here is has a 2010 MK6 TSI using GTI suspension. I guess my argument here is that while I dont want to fork out to much upgrading to new suspension I would mind a slightly firmer ride. Also am I right in assuming that the car would sit lower then it would with stockies?!
    ps, if this is a stupid idea by all means let me know.
    Sep 2012
    i think the GTi sits 15mm lower,
    Current - 2015 Tiguan 155 R-Line.
    Previous - Jetta MkV 147 Turbo, Viezu Raceday mapped, Carbonio CAI, Quad Exhaust System, R8 Coil pack, Whiteline Swaybar, GTi Steering wheel with paddles, Alloy pedals, RNS510 & Leather.
    Erskineville, NSW
    All been done before.
    Mk5 GTI should fit as well.
    Dec 2013
    Thanks for the replies, thought I would have been done many times over already. 15mm doesnt seem all that much lower altho the GTI's seem to have a much lower ride height over the stock TSI's.
    Erskineville, NSW
    You'd need to do dampers, springs & F&R sway bars to get the full effect. Front sway bar is a pain.
    If you are DIYing then fair enough but if you are paying workshop rates then there are better ways to spend your money.
    Dec 2013
    There someone here on the forums with fairly newish GTI stock suspension. While my TSI only has 50K km for the price which he is asking thought this route the best bang for buck. I also read on another thread about replacing the springs for H&R's which also lowers the car by about 20 to 30mm I think. i guess that's another option.
    Erskineville, NSW
    What are you actually trying to achieve or change?
    Do you like the stock ride height but want a firmer ride? Better handling? Flatter cornering? You haven't really been clear
    Dec 2013
    A lower ride first off, dont mind a stiffer feel to the car but nothing too dramatic. Also at some stage I will be getting some 18"s put on the car and dont want the guards sitting 3" off the top of the wheel.
    I will probably get the suspension "upgrade" if you can call it that. I'll take some before and after shots as I work though everything.
    Jan 2011
    Brisbane - QLD
    I did that to my wife previous mk6 118tsi. Bought a set of mk6 gti springs and shocks off a forum member to eliminate that 3" gap between tyre and fender. It stiffened the ride, reduced nose dive, sharpened the handling, etc etc... but nothing too dramatic.
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Dec 2013
    Quote Originally Posted by nat225 View Post
    Well then it looks like i'm headed kinda down the right path. Thanks for weighing in Nat225.
