Nice choice in wheel mate, always looks pretty banging.
Firstly, the .:R will look better on 19s (unless you are lowering by a fair amount).
Secondly I have read varying reports but am still unsure, different rolling diameters F&R can produce negatvie effects with haldex. Have a search on R32OC.
Knowing the standard wheels specs are 18x7.5 ET43 (pretty sure, haven't had mine off to look yet?!), plug 18x8 ET45 into a "wheel offset calculator". Use a ruler to approximate how far out the wheel will move. In this case not too far. This is where the addition of a spacer (20mm) will increase your offset and give a final ET25. Measure that figure from your wheel face and that's where it will sit.
An N/A .:R probably doesn't need 9" wide wheels, but I'd go those all round in this situation.
Then make sure you lower it to make sure it looks together, not half done
HTH
