Results 21 to 30 of 38
Thread: Mk3 Suspension race set up...
  1. #21
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by rayray086 View Post
    Generally a stiffer sway bar would mean a stiffer chassis, reducing the amount of weight transfer when going through a corner. This makes for more predictable control over your car, and I'd take a good guess that that's what you want in a race-spec car. However, this would also result in harsher ride quality, so a really thick sway bar would generally be undesireable in a street car. . . .
    I ditto this comment however your spring rates will be the factor in how comfy your ride is, not so much your sway bar. from what i gather if you were to purchase the 28mm bar you wouldnt need to rely on your springs as much to keep your car from rolling during corners and thus you can choose a lower spring rate which wont be as harsh under normal straight driving; and visa versa . . . as is mentioned just above, get down to any motorsport involved companies/shops and question them about itm and if possible have them set it up for you . . .
  2. #22
    Aug 2006
    Melbourne VIC
    Aug 2006
    Melbourne VIC
    Sep 2006
    West Sydney
    I've heard good things from Americans about Autotech's products!
  5. #25
    Feb 2007
    Perth, WA
    So water boy, what did u decide on?
  6. #26
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by MattyT View Post
    Use standard legs with Koni inserts with adjustable bump and compression and Koni 2 way springs... Fully adjustable.... Around $3300
    I got to pay for my panel work first
  7. #27
    Aug 2007
    For that price you can get KW V3's fitted and have your car counter balanced...
  8. #28
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by FknDubbin View Post
    Sorry that price includes, poly bushes all round, camber kit and front bar....
  9. #29
    Feb 2007
    Perth, WA
    What poly bushes did u get?
  10. #30
    Sep 2006
    West Sydney
    Quote Originally Posted by Water Boy View Post
    Who's doing your stuff?
