what springs did u use to lower the car?
It would seem apparent after my latest purchase that ALL golf 4 stud wheels should be fairly easily interchangable.
the mk4 rims i just bought would have to be close to the last made in the 4x100 stud pattern.
the rims are 14" diameter, 6J (6") wide with a ET35 mm offset.
with 185/60 rubber, these wheels fit very nicely on my mk1, which is quite low (see signature pic) i have slightly puled my guards on the front (literally) but i did this with my old rims (same spec but ET38 ) and they didnt rub anyway.
because of the low ride height, the rear sometimes scrapes with a load in, but only on the flares, not the lip itself - i fear this would be a different story with more than 5mm spacers.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
A mk1 GTI had 175/70-13s as std the Campaign had 185/60-14 on 6 by 14 wheels.
A lot of folk fitted 205/60-13s on the std 13 inch wheels.
standard mk1 wheels are 13"x5" for diesel and 13"x 5.5" for petrol.
standard diesel tyres are 155/75 r13 and for petrol the standard is 165/70 r13.
the gti got 175/70 r13's and required lower stress bar because of the extra grip allowed by the wider tyres (according to the design papers) and hence higher forces on the chassis.
when the mk2 came out there was a short run of 175 tyred cars and then im pretty sure most had 185's from then on
'99 A4 Quattro 1.8T
GLD 155SR13 with 4.5x13 ET 45 wheels
GLS/LS 155SR13 with 5x13 ET 45 wheels
GTI 175/70HR13 with 5.5x13 ET 38 wheels
I suppose the only way to solve the rubbing issues is to roll/pull the guards out more or change your tyres.
Your current 185/60 tyres on 14" wheels are 16mm taller in diameter compared with the stock-specced 155/75 tyres on 13" wheels. Fitting tyres with a lower aspect ratio would get it closer to the stock figure, and may minimise your rubbing issue. For example, 185/55 tyres on your 14" wheels will be 2mm shorter than the stock-specced wheels, and it'll be closer to the stock rolling diameter, meaning less speedo/odometer variation. The gap between wheel and fender would be increased too (though only by 9mm, seeing as the wheel is mounted in the middle).
Another solution would be to fit on slightly narrower tyres, e.g. 175/60 or 165/65 on your 14x6 (which will be respectively 4mm and 8mm taller than the stock-specced rolling diameter, so no issues with speedo readings). It'll decrease the amount of tyre bolge on the edges, which may help with clearance. I don't know how bad it is to stretch tyres, but it seems to be really popular with the VW scene in the US and Europe? It allows the user to fit the widest possible wheel on, and by fitting as narrow a tyre as they can, they can drop it real low without (too much) rubbing issues... I suppose this picture illustrates this concept quite well:
Personally, I think it's insane, but people do it![]()
By the way, this was the website I used for finding the rolling diameter measurements: http://www.rims-n-tires.com/rt_specs.jsp
Golf 2 wheels (14x6) with 185/60x14 tyres will fit without any problems, but the Golf 3 wheels of the same size with more inset have been known to rub on the struts of some Mk 1s.
'99 A4 Quattro 1.8T
