Results 1 to 10 of 15
Thread: mk1 15" tyre size help
    hey dudes
    so my 15x6" steelies are painted and ready for some rubber, only prob is deciding which tyre size.
    My car is currently on King springs, so is not mega low and i think having a tyre with a too low a profile (giving a diameter less than stock) might look weird...
    Having said that i don't want no commodore tyres!
    Wouldn't mind a bit of stretch, and keeping the wheel+tyre diameter close to what it should be.
    I have spoken to a few tyres shops etc, and the best I have been able to find is 195/50/15 which is pretty much bang on daimeter wise, but i was hoping for something narrower. I have asked around for 175/50/15, although apparently these are not easy to find.
    anyone got any suggestions?
    Gosford Central Coast NSW
    i dont think you'll have a lot of choice. 195/50 is fairly common, anything else is getting rarer for small 15" tyres.
    i have a set of 15x6 steelies too sitting here, but i'm thinking i might cut them up and put the inners inside some 7" commodore barrells
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    Eastern Suburbs Melbourne
    165/50, toyo and nankang do them,. that'll be the only tyre that'll give a little bit of 'stetch'
    or 185/45 if you want a bit of a wider foot print. (nankang)
    There might be some more manufacturors that do those sizes too, but i know for a fact about the ones that i mentioned, cause i've seen them in real life!
    dont go 195/50, that'll be ballon and look bad. imo.
    i like volkswagens
    thanks dudes!
    they sound like decent options Jarred, although both of them will decrease the rolling diameter by about 5%. that's all cool, but i'm worried that'll look silly when my car is just on lowered springs and wheels aren't tucked...
    maybe not though... any ideas where to find them?
    if you get a 195/50 with a gutter protect strip it wont look like its ballooning too much
    just found that you can get ecocontact EP (great tyres, have them on my mk1 - very good in the wet) in 15" and they do
    145/65R15 72 T 190 355 4.0 - 5.0 577
    175/55R15 77 T 190 412 5.0 - 6.0 581
    195/50R15 T 190 585
    thats: size - sidewall - load rating - max speed - load capacity - rim width - overall rolling diameter.
    '99 A4 Quattro 1.8T
    195/50R15 T 190 585
    cheers gldgti!! those 175 ecocontacts sounds like a good option. now i just need to find out where i can get em from. were yours expensive? thanks again.
    Jun 2007
    the 165/50 is still the same profile as the 195/50, so from side on, it should look pretty similar.(height wise) although it will actually be slightly less side wall cause of the tiny bit of stretch.
    i agree the 185/45 would possibly look bad if you're not tucking, or close too. (ie, now wheel arch - tyre gap.)
    http://www.tyrestretch.com/6_165_50_R15/
    this isn't a 195/50, but it's close, should give you a slightly rough idea..
    http://www.tyrestretch.com/6_186_55_R14/
    EDIT: tyre stretch and "look" is all very dependant on the make of the tyres themselves too btw. pronounced rim protectors will give the illusion of stretch on a fatter tyre.
    i like volkswagens
    i'm not sure if you might have the wrong end of the stick there bloke.
    165/50 has a 50%x165mm (or 82.5)mm sidewall. 195/50 has a 97.5mm sidewall.
    thus, the rolling diameters are quite different, even though the ratio of tread width to sidewall height is the same (50%).
    you could say that the 165/50 is a "smaller" tyre than the 195/50. it will look different though. i went from 205/45 to 195/45 on my mk3, and you definately notice both the reduction in diamter, and that the car looks higher. HTH
    '99 A4 Quattro 1.8T
    Quote Originally Posted by funkamedic View Post
    i have a nice little backstreet tyre place i go to, and i got mine (185/55/14) for $90 each.
    i really cant rave enough about them. for a light car, i'd class them in high performance, despite the "ecocontact" branding.
    '99 A4 Quattro 1.8T
    Jun 2007
    97.5 - 82.5 = 15mm. which is 1.5cm.....
    1.5 CM! I'm well aware of the difference, but it's so minimal, that' it'd be pretty hard to pick, unless you had the two tyres next to each other!
    Hope that clarifies what I had previous written.
    i like volkswagens
