Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: mk1 15" tyre size help
    Thanks again guys. I have sent out a few feelers for some of the tyre and sizes mentioned and will hopefully get a few replies.
    if anyone else has any other ideas re sizes or where to source some of the above mentioned options in Bris then let us know! i just wanna get these wheel fitted
    cheers
    ant
    Gosford Central Coast NSW
    97.5 - 82.5 = 15mm. which is 1.5cm.....
    1.5 CM! I'm well aware of the difference, but it's so minimal, that' it'd be pretty hard to pick, unless you had the two tyres next to each other!
    hence why i said:
    Hope that clarifies what I had previous written.
    well yeah, but over the whole tyre thats 30mm.... thats a lot! trust me, you'll pick it.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Aug 2006
    Melbourne VIC
    I run 195/50/15 tyres on 15x6 steelies with a rim protector and they look fine. I using Bridestone Firehawks http://www.bridgestone.com.au/tyres/treads/tz100.aspx
    Quote Originally Posted by Water Boy View Post
    cool. have you got any pics handy Water Boy??
    Jan 2006
    You'd be surprised, I noticed a difference when going from 195/50's to 195/55's. That's just under 2cm difference in rolling diameter, approx 10mm of sidewall difference. I noticed that the car didn't feel the same to drive, it didn't accelerate the same. It even looked different, less low profile. I'm sticking with 195/50's from now on.
