Originally Posted by
An7on
G'Day All,
I've found a set of wheels I really like...
But the centre bore diameter is 66.6mm. With the Mk5 bore being 57.1mm will I need an adapter (if such thing exists)?
Or will they centre by way of the wheel nuts...Am I playing with fire?
Hub rings required. 66.6 - 57.1 are common. I use them with my Audi A4 wheels
What size & ET are the wheels as Mercedes rims often have too much poke
Local $23
Wheel HUB Centric Rings Spacer OD 66 6mm ID 57 1mm Aluminum Alloy | eBay
plastic - $19 - ex-UK
Alloy Wheel HUB Centric Spigot Rings 66 6 57 1 Wheel Spacer SET OF 4 | eBay
alloy - $14 - ex-hong kong
4pcs Aluminum Hubrings 57 1mm CAR HUB TO 66 6mm Wheel Bore FOR CAR Auto | eBay
edit: I really should read the other posts before replying....
