I feel your pain bro, I'm in the same boat, I'm gonna buy some black bolts, they will still look good.
Btw did you find a solution?
Hi all, just put on some 19" talladega replicas on my mk6 golf gti - used the same bolts etc. However, the plastic caps that go over the bolts no longer fit, too large! Any solution, will VW dealer have smaller caps?
Sorry if this is a stupid question, first time I have come across this. Thanks
Current: '11 Renault Megane RS 250 Cup Trophee - Manual - All Options - Stage 1 Bluefin
Ex: '10 Nissan 370Z - Coupe - Manual
Ex Ex: '10 VW Golf GTI - 3 Door - Manual - All Options - Stage 1 Bluefin
Easiest and most common way to sort this out, is to instead of using the stock covers, make your own out of sikaflex. Just squirt it around the bolts in the bolt holes until they are completely covered. Then simply smooth it out. Looks much better.
Sent from my GT-I9305T using Tapatalk 2
I had the same issue when switching to aftermarket rims. Ended up getting a set of black covers from ebay uk. A set cost around $25 all up, and fit perfectly.
These are the ones I bought if it helps:
UAS Black Wheel Bolt NUT CAP Cover SET 17mm HEX 20 Pieces Plus Removal Tool | eBay
2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
