50-60mm just on springs would leave you with a very very stiff ride. As oyu have no doubt found out, a "normal" drop for springs is prob max 40mm.
If you really must avoid coilovers (a quality set will be better in all departments then firmer springs on stock shock, you can afford them, you bought a passat), you may be able to get Kings (shuddder) or someone to make custom springs for you...
