5x112 will bolt straight up.
CB should be fine (may need hubcentric rings, cheap from any wheel and tyre shop)
Width, 8" is not that wide.
Offset, I'd imagine the 8s have an ET of around 35 ?? This could be "too aggressive" and make the wheel poke, or you could make something pretty unique. Only problem is you will need to be very low on coils or use airride to achieve the right look.
Try a wheel offset calculator and use a ruler to check.
What colour car?
I'm thinking if you are looking at cars like that for inspiration you know what is required, and therefore should just do it and love doing something different![]()
