Results 1 to 10 of 15
Thread: looking at putting new wheels on the passat
    Mar 2011
    Wareemba, NSW
    Exclamation looking at putting new wheels on the passat
    hi guys, my new (to me) passat has some small scratches on the wheels and being the perfectionist that i am, i'm looking at replacing them.
    my current ones are "montreals", 16x7, 5x112, 57.1mm bore, et45 and weigh 18lbs.
    the ones i'm looking at are "biolines", 16x6.5, 5x112, 57.1mm bore, et50 and weigh 22lbs.
    obviously there are some small differences in width, offset and weight as they are jetta wheels however i'm unsure of how this will affect the look and ride of the vehicle. any advice would be greatly appreciated guys! cheers, ben
    Jun 2009
    You should be looking for 17 x 7.5 ET35 for mad hellaflush fitment!
    Curious as to why you would pick a thinner wheel with a higher offset that weighs more?
    I would be going lower offset, wider wheel and less weight if it was me.
    Mar 2011
    Wareemba, NSW
    i'm basically just looking around to see what's available.. the others i had my eye on are 17/8s with 245/45/r17s and a 26 offset. these are off an audi a5. would these be any good? any suggestions?
    Aug 2006
    get 20x8.5 Et 35 225/30/20
    First suggestion will look worse, as wheels will sit further in the your old wheels, and from the rear itll look silly going skinnier wheels. you most likely wont notice, but the handling may become slightly worse due to be the wheel track being smaller.
    Your second suggestion on the other hand sounds better. It may come out to far though due to the offset vs width as the 245 will have a bit of fat
    what size tyres do you currently have? and is the car lowered/planned to be lowered?
    something like what team_v suggested would be best...
    Try these. in your case id be watching the over all tyre diameter and how much the wheel in and out away from the strut and arch.
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Wheel Offset Calculator
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2011
    Wareemba, NSW
    sorry guys, current tyres are 205/55/17 and not lowered (as far as i know).
    Quote Originally Posted by 00 VW Passat 20v View Post
    guessing you mean 205/55/16? as your wheel size above.
    if it is 205/55/16, you could get a 17x7.5 et35 (as team v) with 225/45/17 or 235/45/17, will suit your car much better
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2009
    so you are running tyres for a 17" wheel on a 16" wheel?
    Edit:
    Damn, Dylan beat me to the point.
    Mar 2011
    Wareemba, NSW
    haha sorry guys, yes the tyres and wheels are 16", sorry for the mistake.
    How much are you willing to spend? and what diameters? theres some nice Passat CC wheels with tyres atm
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
