Results 1 to 5 of 5
Thread: Legality of re-drilled wheels?
    Jul 2005
    Melbourne, Williamstown
    Hey people,
    Was wondering if anyone knows the legality of redrilling wheels?
    I picked up a set of audi a3 telephone dials for free that the previous owner has redrilled to the golf stud pattern but said to make them legal/roadworthy you have to weld up the old holes? Does anyone know if this is the case? I know there are plenty of multi fit wheels out there but thats slightly different I know.
    Cheers.
    mk2 GTi 16v
    Corrado G60
    Jul 2005
    Anyone know?
    mk2 GTi 16v
    Corrado G60
    syncro Guest
    Maybe ask a wheel maker/modifier/repairer?
    I think it's a bit of a grey area.
    Perth. WA
    Re: Legality of re-drilled wheels?
    Quote Originally Posted by ausgolfer
    Hey people,
    Cheers.
    been through this before...
    Alloy wheels gain there strength from the heat treatment applied to the wheel... WELDING holes up removes the heat treatment properties from the wheel. If you still require to do this for a road vehicle, you will likely need either an engineers certificate quite likely with input from a metallurgist.
    might be fine for your bush hack, but to do this to a higher powered road car is risky to say the least...
    The info supplied to me came from a previous employer metallurgist who has strong affiliation with the automotive scene. Now as for the legality, you would have to sus that out from your state authorities..
    best of luck...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    syncro Guest
    I have seen professional redrilled wheels and would not have a problem with them.
    The ones that I have seen have not been welded, but have had an insert pressed into the wheel. I think they would be legal as long as it was done by a licenced wheel repairer.
Similar Threads
  1. Which wheels will fit
    By DVR68U in forum Wheels & Suspension
    Last Post: 12-08-2016, 12:46 PM
  2. wheels Mark V TDI
    By Rod_H in forum Wheels & Suspension
    Last Post: 18-01-2007, 04:06 PM
