Results 1 to 10 of 39
Thread: leaglity of ride height...
McDub leaglity of ride height... 22-03-2010, 09:44 PM
Preen59 Because most people are... 22-03-2010, 09:56 PM
dylan8 When used correctly with the... 22-03-2010, 10:03 PM
Mrk_Mickey I find it hard to believe the... 22-03-2010, 10:04 PM
McDub it is according to page 14 of... 22-03-2010, 10:09 PM
Yevvy i reckon my front lip was... 22-03-2010, 10:12 PM
Preen59 Yes well tyres are dangerous... 22-03-2010, 10:05 PM
Tim I think its just morons that... 22-03-2010, 10:11 PM
mikinoz But you can get 10mm lower... 23-03-2010, 12:46 PM
Manaz Spacers CAN be dangerous if... 23-03-2010, 03:20 PM
Preen59 You flawed your own argument.... 23-03-2010, 07:14 PM
GTom the 100mm is measured from... 23-03-2010, 07:42 PM
dylan8 not arguing or anything, but... 23-03-2010, 08:26 PM
McDub i don't think that's right... 23-03-2010, 08:34 PM
dylan8 drop it on its guts and find... 23-03-2010, 08:56 PM
McDub probably true, but i'm more... 23-03-2010, 09:10 PM
GTom Yep you're right on the... 26-03-2010, 08:05 PM
simza in tassie the car has to be... 03-08-2010, 03:48 PM
gareth_oau be interesting to challenge... 03-08-2010, 06:54 PM
dylan8 true, let alone suspension... 03-08-2010, 06:58 PM
McDub sound pretty dumb, as dylan... 03-08-2010, 10:12 PM
Manaz Out of control cars have a... 23-03-2010, 09:33 PM
trickysimon Ask and you shall recieve :P... 03-08-2010, 06:16 PM
dylan8 Could go country on that... 03-08-2010, 06:38 PM
trickysimon Haha bull. I manage to scrape... 03-08-2010, 06:40 PM
Spyda True. :thumb: 23-03-2010, 03:48 PM
dado first thing insurance will... 23-03-2010, 06:52 PM
    Apr 2008
    the 100mm is measured from the centre of the vehicle (B pillar area)
    On top of the above there's also a measurement from the ground to the centre of the headlights (i think from memory it's can;t be lower than 590mm)
    And also a gap between the tyres and fender (the size of the gap I'm not sure but it's one of those ambiguous ones)
    My car satisfies most of the above or comes very close to the standards.
    Quote Originally Posted by GTom View Post
    not arguing or anything, but where did you get those from? is that for NSW?
    how does that work with cars with low mounted headlights? and every second car is tucking tyre, that would be a odd way to measure things.
    Dont the police just have a ball 100mm in diameter on a pole, and if it jams under the car your below the limit?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    i don't think that's right according to this
    http://www.rta.nsw.gov.au/registrati...s_nov_2007.pdf
    "3. Ground Clearance
    A vehicle or combination must have a ground clearance of:
    a. at least 100mm at any point within 1 metre of an axle; and
    b. at least one-thirtieth of the distance between the centres of adjacent axles at the mid-point
    between them; and
    c. at any other point - at least the distance that allows the vehicle or combination to pass over
    a peak in a road, the gradient on either side of which is 1:15, when the wheels of one axle
    of the vehicle or combination are on the slope on one side of the peak and the wheels
    of the next axle are on the slope on the other side."
    seems you may have mixed up A and B
    But still, makes me wonder if it matters that the plastic guard under my car counts, i wouldn't think so, but who knows.
    Quote Originally Posted by McDub View Post
    drop it on its guts and find out.
    i bet you'll do damage to your car before the law pays one bit of interest
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    probably true, but i'm more concerned with the insurance side of things rather than the defect side of things.
    i'm just surprised that the lowest point on my stock height car is 110mm!
    which suggests a very minor drop of just 10mm will make it illegal... though this suggests to me that it's more the solid parts of the car, and that they shouldn't care about a plastic belly/guard, which if you really wanted to you could just remove anyway!
    Apr 2008
    Yep you're right on the measurements. Most of the info that I got came from HWP.
    There's an ADR on the headlights I'm trying to find it, It's in the vehicle lighting ADR.
    May 2010
    Launceston, Tasmania
    in tassie the car has to be same ride height as show room floor.. if its lower then its illegal and therefore not insurable.. which is kinda poo really.. so each state is different.
    Jan 2008
    Canning Vale, Perth, WA
    Quote Originally Posted by simza View Post
    be interesting to challenge that law.
    A bog stock falcon sits higher than say an FPV equivalent, so how can putting FPV suspension in your bog stack falcon make it illegal?
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Quote Originally Posted by gareth_oau View Post
    true, let alone suspension sagging over time
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2008
    melbourne
    When i had the bora i had around 92mm clearance on the sump and had no issue's getting a roady either
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
