Results 1 to 8 of 8
Thread: Increasing Rim size
    Dec 2007
    Increasing Rim size
    Hi All,
    I am currently running on 165/65 R15 and I want to move up to 17" without compromising the rolling radius.
    Can anybody help in advising what set up I should be at to achieve this (???/?? R17 )
    Cheers,
    Nov 2006
    This is the site you want!
    http://www.miata.net/garage/tirecalc.html
    Nov 2006
    205/40/17 ?
    Dont know if its an easy size to get though.
    Dec 2007
    Quote Originally Posted by SoVeReIgN View Post
    205/40/17 ?
    Yeah 205/40/17 is actually spot on.
    With regards to the actual tyres itself, i think i gotta start making a lot of phone calls to see if they have got any.
    Thanks SoVeReIgN
    Dec 2006
    Kilsyth, VIC
    What will fit is a good question to be asking about now...
    215/40R17 is a more common tyre and will be put your speedo out by 1.4% (reality is that this will most likely make it more acurate as most speedo's read under anyway).
    Jan 2008
    Melbun
    try this site too.. similar but more info www.rims-n-tires.com/rt_specs.jsp
    is your caddy one of the new ones? if so it doesnt have 165 tyres... it should have the same as the golf ie 195/65/15 and hence 225/45/17 would be the go. maybe double check on that one.
    2x Caddy, 1x Ducato
    Dec 2007
    Quote Originally Posted by Mischa View Post
    Nah, my Caddy is a 2005 model. I saw the attached picture on this site a while ago and ever since then, all ive been doing is saving my money to do up my Caddy exactly like it The only thing I want different on my Caddy are the attached rims.
    I do have one more question about the rims/tyre size...........would increasing from 165/65 R15 to 205/40/17 cause any problems and would it require any modifications to the rotors, suspension etc...
    Cheers,
    That is one cool caddy! It may look a bit higher depending on what tyres you fit.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
