205/40/17 ?
Dont know if its an easy size to get though.
205/40/17 ?
What will fit is a good question to be asking about now...
215/40R17 is a more common tyre and will be put your speedo out by 1.4% (reality is that this will most likely make it more acurate as most speedo's read under anyway).
try this site too.. similar but more info www.rims-n-tires.com/rt_specs.jsp
is your caddy one of the new ones? if so it doesnt have 165 tyres... it should have the same as the golf ie 195/65/15 and hence 225/45/17 would be the go. maybe double check on that one.
2x Caddy, 1x Ducato
Nah, my Caddy is a 2005 model. I saw the attached picture on this site a while ago and ever since then, all ive been doing is saving my money to do up my Caddy exactly like itThe only thing I want different on my Caddy are the attached rims.
I do have one more question about the rims/tyre size...........would increasing from 165/65 R15 to 205/40/17 cause any problems and would it require any modifications to the rotors, suspension etc...
Cheers,
