Cheers guys. so much easier to find info when you search 'white worm' along with vw/wheel etc.
Have any idea how much that would sting me to get some one to strip and recoat? might just get rid of them like i had originally planned...
I have same problem with my allow wheels on Ford Falcon...and it's original factory FORD wheels.
R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
Only problem with painting them black dyl is that you would still have to get the clear stripped back or sand it back, then you still have to paint them and clear again.
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
whip em off, get your stockies back on to roll on, rub back with fine paper 800 - 2000 grit, polish and re-clear coat.
lucky they're not machined looking faces....
87' MK2 GTI
13' MK7 TDI
I'd probably just use thinners to get all the clearcoat off, then give them a good prepsol/wax and grease remover, then re-clear.
You could probably even blend the clear, to save yourself cleaning and coating the whole wheel-face. Just use thinners on the affected areas + a little bit more.
whats the best way to clear coat? is it something any idiot (me) do at home?
