Update - Turns out that the spacers i got are p00 and are wheel centric and not hubcentric. That means there is no weight on the hub and all the weight is on the 5 wheel bolts (poor little wheel bolts). I made it to work but then changed a few things on the way home.
What i did was remove the 5mm spacers on the fronts and fixed the clearance issue of the slight rubbing by removing the brake caliper retaining clip/spring. Research shows its not really that needed, and i experienced no adverse knocking or noise from break operation in forward or reverse. The rears need the spacers as un-spaced they do not clear the rear rotors.
What i did experience however was absolutely WOEFUL handling from the now-offset geometry between fronts and rears. As in, the fronts are now 10mm total inboard of the rears. As a result the turn in is very lazy and very floaty. The car feels positively unstable at 90+kmh which isn't fun. I actually don't want to driver her and with all the stupidness i've gone through it's kind of wearing me down.
If i nabbed some 2mm spacers from ECS
Volkswagen Jetta IV VR6 24v > Wheels > Spacers > ES#116 VW / Audi Wheel Spacers - 2mm (1 Pair) - ECS#241KT-A then the geometry would reset back to stock (well, 2mm more than stock, but at least the track would be equal side-to-side and front-to-rear).
I then wonder if I need my sways upgraded too. I'd really need to get some sort of advice, this is really getting to me.
