Results 1 to 10 of 19
Thread: how low can you go!
    Jul 2011
    NEWCASTLE NSW
    how low can you go!
    ive seen this argument before, but im starting it again.
    without coilovers, or bags. no i do not want coilovers or bags.
    how low can you go springwise, without shocks. im a tightass and dont mind a bumpy ride.
    im thinking 50mm front, 60-70cm rear. ( UPDATE: 60-70cm is ridiculous, i oughta beat myself ) would look pretty though.
    opinions?
    UPDATE: ordered eibach sportlines, 50mm front 35mm rear. $300, installation $150
    DONE!
    Aug 2009
    ACT
    what exactly are you asking here? If you can run shocks without springs?
    What are you reasons for not wanting coilovers? Even if you do manage the drop youre talking about on stock shocks, they wont last long before you ruin them..
    Jul 2011
    NEWCASTLE NSW
    to avoid ruining shocks should i stick to 50mm?, ive seen many guys running them on stock shocks with no issues?
    you'd be better with coilovers on that sort of drop surely, especially if your not changing shocks?
    ... and my 2 cents, drop it even all round or lower at the front. but thats just me.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2011
    Sydney NSW
    From a registration point of view, you must have a minimum clearance between the bump stop and where it strikes the suspension, and then there is a minimum ground clearance. If memory serves me right, it is 50 mm each. The pits at Roseberry had a 50 x 50 angle around the opening of the inspection pit, and to be passed, the vehicle had to clear the angle. This is at the manufacturer's rated kerb weight.
    Jul 2011
    NEWCASTLE NSW
    something about reverse rake, it looks bagged i guess. i think ill go 50mm front and rear. its tried and proven to work for cheap $$$
    Jul 2011
    NEWCASTLE NSW
    good info wai.
    the tdi is at tiguan height at the moment. pics of a few of the guys on here with 50mm still looks safe. can still fit a finger between the wheel and guard.
    Oct 2010
    Melbourne, VIC
    As benough & I said in the diesel thread, it will ride and handle like crap, especially as the dampers wear and they will wear much faster than normal due to being worked harder by the higher spring rate
    Apr 2008
    You're keen!
    I'm not sure I went down 50mm with my V3's.
    Buy what springs will do the ride height but just be prepared for the consequences
    Jul 2011
    NEWCASTLE NSW
    its a 211k car that as far as i know has never had its dampers replaced.
    when they do give up, ill get koni's or bilsteins
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
