Results 1 to 10 of 11
Thread: Can't get lock nut off rear wheel
    Nov 2009
    Perth, WA
    Hey Guys,
    Trying to install some mudflaps and I got 3 done, but when trying to get the lock nut off the rear right wheel I just couldn't do it.
    I tried until it felt like I was just stripping the nut.
    Any ideas on how to get it off?
    MY11 MKVI Golf Wagon 103TDI | Platinum Grey | DSG | RNS510 | MDI | Bluetooth |
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by pat25d View Post
    Hey Guys,
    Go to your local tyre shop and get them to use the rattle gun,you can then drive home on 4 nuts .
    Go to your local tyre shop and ask if they can remove it for you with the rattle gun.
    are you using your OEM wheel brace?
    if so stick a bar over the end of it to get more length and power.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Nov 2009
    Perth, WA
    I am using the normal brace.
    It is slipping off the nut though, so even if I had more leverage it would still slip.
    Might try the rattle gun idea.
    Jan 2011
    Brisbane - QLD
    don't go to any tyre shop, it's likely your key and lock bolt are rounded.. and they would just try to unbolt it with a breaker bar or a rattle gun... but it might cause more damage than fix.
    go to your local VW service, if your key is rounded, they have a master key.
    it happened to me earlier this year. i tightened all bolts so tight with a longer wrench (big mistake!), then when i needed to take the wheels off, all 4 lock nuts got rounded and paint on the wheel got damaged...
    i went to a local tyre shop, they tried with a breaker bar, failed..
    booked in at VW service, they spent 30mnts or so with a hammer, rattle gun, breaker bar, a master key.. then the rounded lock nuts all came off and put new set of lock nuts in.
    i think the Mk6 lock nut / key design is just not good.
    i now use a torque wrench whenever i need to change my wheels.
    Feb 2009
    Sydney, Australia
    hehe... I think some people overtighten their nuts
    Nov 2009
    Perth, WA
    Quote Originally Posted by Corey_R View Post
    I'd happily take the blame but this is the first time I have tried to get it off.
    Jan 2011
    Brisbane - QLD
    cos nuts are precious... :p
    Jul 2011
    Victoria, Malvern
    If you've had the tyres changed by a third party tyre place then it's most likely happened there.
    I haven't heard of this much with VW apart from some cross-threaded bolts on after market wheels, but at work we get a few of the new BMW X6M/5M locknuts in that have had the key busted.
    Most likely the "master key" is an old school drill bit system, and you drill in a little bit wider each time until the head just pops off. Or maybe VW is one of the few manufacturers with a legitimate solution to this issue.
    Black Golf Mk6 TSI Manual
    Jan 2008
    Newcastle, NSW
    VW keep a set of all the master keys and match them up to which one you have.
    Yes you can drill, but it can be pretty hard steel on the lock nuts and difficult to drill, especially if using a cordless or something.
    Get an imperial socket a little bit smaller and a small sledge. Use a 6" extension and belt the socket onto the stud and then crack it off.
    Had to do this today.
    If you are skilled with punches and chisels, by all means.
    Weld a 16mm nut (weld on the inside with the thread) and leave clearance for a 2omm socket around the outside. Be careful you don't heat the rim though.
    Tighten first, then impact along the centre axis (belt the front face with a dolly) then try and loosen it that way.
    HTH
