Results 1 to 4 of 4
Thread: How to get a stiffer ride without lowering
    Hi,
    can i just get some stiffer rated springs and replace the existing springs to make the ride stiffer? polo gti stock springs seem so soft, especially like around round abouts.
    question2: there would not be a point to get coilovers or a shock/spring combo without getting car lowered? i dont want to get the car lowered cause it's frustrating with speed bumps.
    please recommend best products to improve handling without lowering.
    *im definitely getting rear sway bar.
    Jun 2009
    Quote Originally Posted by vanllinx View Post
    Hi,
    Rear sway bar would help.
    Wider wheels would also help due to a larger contact patch of rubber.
    Aug 2006
    Allsprings at liverpool can make standard springs stiffer..
    i think they heat them up and change it but keep the stock height!
    Apr 2010
    Sydney,NSW
    You can change the shocks too. My previous car was a Nissan X-Trail, they are like a boat, all I did was fit a whiteline rear swaybar and a set of Koni adjustable shocks, with the shocks set to soft it was like stock, with them set to firm there was virtually no body roll and it handled like a performance sedan.
    I have put Heavy Duty Bilstein shocks on my Bora (stock springs) and it has firmed it up nicely without reducing height. I think it would benefit from a thicker rear swaybar too but that is mostly to reduce the understeer.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
