Tyres are too big !
Hey guys,
Im a little stuck, its been approximately 48 hours since my new set of hot tuning coilovers were installed into the mk1, and the fronts just aren't dropping to anywhere near what i'd like. With 185/55/15 i've still got a good inch of wheel gap in the front. The rears seem to be fine.
What have i done![]()
Tyres are too big !
You should be able to go silly low. My bet is you've been given mk2 coils
I have a set on my Cab and the sump will touch the floor if I wound them down enough. I have about a couple of inches between the tyre and the wheel arch just to prevent scrubbing.
Put a picture up of the coilover .
1993 MK1 CAB ! Work in Progress........
pull out the helpers and bump stops
Sent from my GT-I9305T using Tapatalk 2
Wind them down lower for starters. How many mm of thread do you have left.
They'll go plenty low.
