I thought helper springs were to keep the main spring captive if the strut fully extends? they are generally 2ish kg/mm so don't really effect the ride quality.
if you want the car higher, raise it. soften the dampers.
perhaps take it to a suspension place, they can corner weight it and have it handling nicely. lower isn't always better, suspension arms need to be at particular angles to work properly.
