if you have coilsovers (i'm pretty sure you do)
I'm assuming since you're going for a 195/50 you're getting a 15x7 wheel. The 195 will stretch over the edge of the rim. And assuming you're running about -1 degree camber, you'll need offset of around ET30 or lower. ET35 would most probably have the tyre rub on the coilover spring, given -1 deg camber. a skinner tyre would allow you to run a higher offset (say a 185/45.)
ET approx 40 for a 6". wheel with 195.
