Results 1 to 6 of 6
Thread: HELP with wheel offset??
    Jun 2008
    I know wabit has posted an offset calculator etc, but I still need some help.
    MK1 CAB (1993)
    Has std 14 inch wheels, 185 / 60/ 14
    Wanted to go to a 15 inch wheel with a 195 / 50 /15 or 195/45/15 tyre.
    Car has been lowered, I dunno 60mm , pretty low.
    When purchasing new wheels what offset should I go for?
    I know std is 38, however as wheel is getting bigger and car is low, need some advice so tyre won't rub...
    Please help me..
    1993 MK1 CAB ! Work in Progress........
    Jun 2007
    Eastern Suburbs Melbourne
    if you have coilsovers (i'm pretty sure you do)
    I'm assuming since you're going for a 195/50 you're getting a 15x7 wheel. The 195 will stretch over the edge of the rim. And assuming you're running about -1 degree camber, you'll need offset of around ET30 or lower. ET35 would most probably have the tyre rub on the coilover spring, given -1 deg camber. a skinner tyre would allow you to run a higher offset (say a 185/45.)
    ET approx 40 for a 6". wheel with 195.
    i like volkswagens
    Jun 2008
    Thanks Jarrod, I am running coils, I cannot recall what the tyre shop set the camber to.
    So presuming all of the above, what offset do you think I could safely go to without rubbing on the arches9If 35 is max before htting the coils) ?
    I could always lift her a little if needed.
    I thought I would be going for a 15x6 for that tyre size ??
    Jun 2007
    well an ET25 on 15x7 will sit flush with the front gaurds on a standard mk 1. I don't know about clipper kits though. With a 195/50 you would need to roll the lips on the standard gaurds, or raise it up a bit. I'm not sure how the clipper kit will affect it though.
    If you're getting a 15x6, I'd defiantly get a smaller tyre, otherwise it'll look balloon. 185, or even 165 if you want some stretch. these aren't cheap sizes though, cause they're odd sizes. 185 is a standard size on a 14x6, so I assume it'd be the same for a 15x6
    BTW: it's spelt Jarred. with an 'e' not an 'o'. Please get it correct next time
    i like volkswagens
    Jun 2008
    Thanks Jarred, how rude of me ....Appreciate your help.
    Aug 2009
    Point Cook, VIC
    give this site a go. quite good. i have it saved in my favourites. you can doe offset calculators, tyre calculators and heaps more.
    http://www.1010tires.com/tech.asp
