I think those 3 are all highly skewed towards the 2nd criteria (particularly the last which is an "everyday" semi-slick).
If the actual order is also is the order of importance, I think you should be looking at a more "touring" oriented tyre (Michelin Premacy, Bridgestone Turanza etc)
Reason: comment about Neova
Resident grumpy old fart
