Results 21 to 30 of 38
Thread: Goodyear Eagle F1 Asymmetric 2 - Tempe Tyres Sydney - 225/40/18 - $250
  1. #21
    Erskineville, NSW
    One of the guys at GolfMkV uses them. He makes big power. Was banned from here. Can't remember his nick.
  2. #22
    Jan 2011
    Brisbane - QLD
    Last time I looked at the Michelin Australia Catalogue, the PSS in 225/40/18 was not listed. Only the PS3 is available in Australia for that specific size and load rating.
    Quote Originally Posted by Martin View Post
    Whoops - I was not paying attention and assumed the post was about PS3 rather than PSS
    I want to try a pair of PSS (can't find them locally)
    I need more grip off the line (stage2 ECU), that's my only complaint
    The PS3 are much better than the EagleF1 off the line
    But when hot the EagleF1 does turn in really good when driving hard
    The Yokohama Advan AD08 should be good but their 225/40/18 is only rated 88W
    They do a 225/45/18 91Y however...hmmm, small speedo error
    Has anybody used the Nitto NT05??? (I was worried they would not perform)
    MINI Cooper S Clubman - FWD
  3. #23
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by nat225 View Post
    Agreed, it's frustrating
    I've been doing some research on the Nitto NT05, looks like they could be a good performer
    They certainly won't last as long as a Michelin PS3 but like I said, I want to be able to put the power down
    (I really enjoyed the day I had the semi slicks on the car - no wheel spin and soft ride)
    I'm thinking of buying two and selling the EagleF1's
  4. #24
    Oct 2010
    North Parramatta, NSW
    Nitto NT05 are in a class of their own. Fantastic performer.
    Even the Invo (which I'll be getting next month) is supposed to be a great tyre.
  5. #25
    Dec 2012
    You'll find the PSS are a step above.
    Even the PS2 are a better performance tyre than the PS3.
    I've finally obtained a pair of Michelin PSS ($Ouch)
    Also going to grab a pair of NT05's to try
    I was aware the PS2 is much better - It's as hard to obtain as the PSS
    (I would also expect PS2 to only last ~25k)
  6. #26
    Erskineville, NSW
    PSS>PS2>PS3
    PSS would be about AUD340each from Tirerack. (buying 4)
    PS2 about AUD370 each from TR
    How does that compare with what you paid?
  7. #27
    Jan 2011
    Syd, NSW
    why PS2 is better than the newer PS3???
  8. #28
    Erskineville, NSW
    Quote Originally Posted by sunny View Post
    The PS3 wasn't a direct replacement for the PS2. It was supposed to be a replacement for the Pilot Preceda 2 & Pilot Exalto 2.
    The PS3 is better in the wet than PS2 but that isn't what Martin is after. PS3 should also last a bit longer than PS2 - again, Martin doesn't seem overly concerned as he appears to be hell bent on collecting a pair of every UHP tyre available
    A few of my mates on another forum have tried both & they reckon that in the dry, the PS2 has the edge on dry traction & turn-in.
    So, it depends on what you want out of a tyre & Martin is chasing dry traction from a standing start. For most users PS3 is a great all-rounder.
  9. #29
    Dec 2012
    Thanks Brad - as usual you are totally on the money
    The PS2 has a tyre wear number of 220 - which is pretty low - it's clearly a sticky tyre
    It was original fitment on cars like BMW Alpina Z8, McLaren SLR and Porsche GT2/GT3 models
    Not the sort of machinery most of us are driving
    The PS3 has a tyre wear number of 320 - which is still pretty grippy
    Based on my wear rate I'm looking at getting 35,000~38,000 km out of them
    They do grip well wet and dry, turn in feel and response is very nice
    It's a great all round tyre - no question about that
    Not a noisy tyre either
    My problem is having updated my ECU and downpipe,
    my FWD car has ~205kw at the front - it was not designed for this - wheelspin galore
    I can't get off the line quickly and I'm fixated on this problem
  10. #30
    Erskineville, NSW
    What pressures are you running up front Martin?
    re: tread wear rating.
    You can use the TWR number to compare tread wear between tyres within a manufacturers range but it's hit & miss when you start comparing (for instance) a Bridgestone against a Michelin.
    The RE050A Bridgestones I have sitting in the garage have a TWR of 140. I know they wear (slightly) better than the numbers suggest.
    The Michelin Primacy HP touring tyres I have at the moment have done 58,000km & will go to 65,000km. TWR is 240. I would have expected them to last about the same as the 46,000km I got from the TWR 280 CSC2 that came with the car but Michelin appear to have added concrete into the rubber mix.
