Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Goodride Tyres - Initial Impressions
    Oct 2010
    Melbourne, VIC
    You can just multiply your distance readings by the size differential to continue to compare mileage - 1.0356 according to the 1010 tires calculator (if you ignore the wear as discussed by brad)
    I'll be very interested to hear your followup reports on these tyres. As brad said, cheap tyres are MOSTLY rubbish but the distortions from China's economies of scale may have allowed a discount tyre to have good peformance.
    Resident grumpy old fart
    Erskineville, NSW
    The apparent economy will have dropped about 5% but in reality it's not.
    I worked this out when I realised I was getting 10 days between fills instead of the usual 9 days...
