Golf MK6/Octavia 1Z Front sway bar installation
OK so whats the secret to changing it?
I couldn't get the subframe low enough to get the stock bar out. looks like the rack is bolted in from the top. is that right? dropped the subframe down probably 100mm but it still wasn't enough to clear it. its possible I needed to twist the swaybar mounts around so it didn't foul on the steering rack.
watched a video of the installation, they make it look REALLY easy haha
I had it on a hoist, plenty of room to move underneath. installed the supaloy anti lift kit while I was there, and a rear sway bar too.
is there a workshop around the ryde area that has done one before that I can take it to for them to install?
cheers
- You may not post replies
- You may not edit your posts
Forum Rules
