OK so whats the secret to changing it?
I couldn't get the subframe low enough to get the stock bar out. looks like the rack is bolted in from the top. is that right? dropped the subframe down probably 100mm but it still wasn't enough to clear it. its possible I needed to twist the swaybar mounts around so it didn't foul on the steering rack.
watched a video of the installation, they make it look REALLY easy haha
I had it on a hoist, plenty of room to move underneath. installed the supaloy anti lift kit while I was there, and a rear sway bar too.
is there a workshop around the ryde area that has done one before that I can take it to for them to install?
cheers
Just found this by searching. Doing mine on an Octavia. Found I had to drop the whole subframe way down - had the front of the car on stands and the subframe on the floor of the garage. Then found that the sway bar mounts are fixed to the bar. I need new ones to install the H & R bar I got. Sod it.
2008 Skoda Octavia Elegance TDI 4x4 wagon
Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
