Results 1 to 10 of 10
Thread: Fuel effiency from different brands of tyres
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Most of our tyre threads are about ride, handling,tread mileage of the tyre. Has anyone researched the fuel efficiency factor of particular brands in Aus. Have noticed one US forum are about how one particular make of tyre over another is getting them much better fuel efficiency.
    Below was one members change in performance after changing brands.
    "American Bridgestone G009's getting 38-41mpg compared to
    Michelin pilot exacto AS getting 48+mpg"
    Sep 2006
    West Sydney
    I believe there are too many factors to deal with when it comes to fuel efficiency. There are a lot of variables that must be kept constant (off the top of my head - tyre pressure, fuel used, time of service, and the heavy right foot) to render those figures significant.
    Jun 2007
    Quote Originally Posted by rayray086 View Post
    Very true ray.
    But wouldn't it be even possible for a heavy footed driver to save fuel if they
    had a tyre that had a better rolling resistance factor.
    I forgot to mention in previous post those figures are for a Jetta TDI
    So it could be possible to save fuel without knowing it. it just depends on
    the tyre and its tread resistance and as you said tyre pressure and maintenance.
    I was just wondering if any others have noticed a difference on fuel
    consumption with different brand of tyres in Aus.
    I think what we need is time and people who are keeping an accurate record
    of there driving style and fuel consumption.
    The forum I was referring to is relating to American tyres for their conditions
    so its not possible to get an accurate picture from Australian brands.
    Do Australian sold tyres have a resistance factor rating.
    Sep 2006
    West Sydney
    Quote Originally Posted by neil View Post
    I guess that leads to another question - what constitutes a "fuel-saving" tyre? Maybe tyre compound? Pattern? And something that relates to "a better rolling resistance factor" - the weight of the tyre? I'd be interested to know!
    I suppose with environmental and fuel resource issues these days being more aware, tests will be carried out to try and raise more awareness on this topic.
    I've been reading some of this too: http://www.carbibles.com/tyre_bible.html
    Some important info I think.
    Jul 2005
    i used to work for a rubber manufacturer in melb years ago and they provided rubber to south pacific tyres which they then added their own goodies to to make all the different compounds of tyre etc for whatever they made at the plant. essentially the base compound is the same. its made the same way all the time and as far as i remember there was only one grade that we made that went to spt.
    i beleive what changes the rolling resistance of the tyre is the amount of silicon they use in them (probably different compounds for each manufacturer as they are trying to outdo oneanother at the mo).
    in the base rubber there is an ingredient that we called antioxidant which gave the rubber its lifespan before degradation due to age - that's why tyres should be replaced before approx 10 years of age regardless of tread left - i remember one year that we used a full tank of this stuff in a few days instead of it going in over a whole month. now those would've been interesting tyres.
    Canberra
    There was an EVO Tyre test article posted over on Vortex by Liam (minigolf) where 9 sets of tyres were tested for various attributes, stopping, cornering, wet grip, etc.
    The worst performing tyre in almost every tested category and the overall worst performing tyre in the entire test (Yokohama S.Drive) delivered the lowest rolling resistance and theoretically best fuel economy.
    In the straight line emergency stopping test, the Yokohamas took more than 12 metres more than the best performing Goodyears to pull up.
    Sacrificing 12 metres stopping distance when I need it most, to save a few cents in fuel just scares me.
    Snowy.
    Dec 2006
    Kilsyth, VIC
    I was going to post along those lines last night, but had to go out drinking with the boys instead
    If you reduce rolling resistance don't you also reduce grip? Sure there would be a mid point between slick and a deep offroad pattern, but I have to think it would be more about how well it disperses water and how noisy it is rather than trying to reduce rolling resistance.
    Sep 2006
    West Sydney
    Quote Originally Posted by No457 Snowy View Post
    Snowy.
    That's some interesting stuff. Could you please post the link over to the thread on Vortex?
    Canberra
    Sep 2006
    West Sydney
    Thanks a lot Snowy!
